can't aquire signal on my bell 3100 sat receiver | SatelliteGuys.US
factory reset just removes all the favourties/timers you have set up
Does it show a signal at all? menu 6-1-1 will get you into the point dish screen to verify
Do you have a working receiver that you can swap it with.?
Or a neighbor where you can connect it, to prove it works, or doesn't......
