Can't get 110 and 119 on dp500? | SatelliteGuys.US
ss3496
2
I can't get 110, I have a dishpro 500. It will pickup 119 fine but no 110. If I move the dish a little I pickup 129 but never can find 110. I have tried the check switch but it doesn't help. I also am only getting odd transponders no even's. Any suggestions????
Thanks Sal
do you have your sckew set? and what is the signal you get on 119?
you have to go to the left and up to get 110
:welcome to SatelliteGuys ss3496.
It almost sounds like the LNB is going bad.
Caller ID
Vip 622 Question About Uhf Remote
