Cant Get A Lock On 110 | SatelliteGuys.US
knightwind
4
I hope this is the right section so here goes........i having trouble getting my dish 1000 to lock on 110 .......im locked on 119 and 129 but no 110....im installing 2 recievers 211 hd and 625 dvr ...i have one cable coming from dp single and going to dp plus twin and the middle 2 going to each reciever and advise would greatly be appreceiated
thanks
Assuming you have your skew set right, it may be that you are picking up 119 and 129 on the wrong eyes. Try covering the 129 LNBF (the middle one) with foil and run another check switch. If you are still getting both 129 and 119 then you need to swing the dish over.
HD channel not working
622 Local HD Guide Information
