Can't get AMC8 alaska channels | SatelliteGuys.US
Lassar
SatelliteGuys Guru
149
Illinois
I had been trying to get amc8 Alaska channels.
According to lyngsat amc8 beam picture, you should be able to get the amc8 Alaska channels anywhere in the nation.
Is lyngsat wrong on this ? If so lyngsat should get their act together.
Have you gotten the AMC8 Alask channels ?
What do you know about this ?
Remember Lyngsat is a Free Project, based on the other side of the world, although not perfect, be thankfull to have it.
While AMC8 may be visible, I believe that TP is spot beamed toward Alaska only.
You can not see it from Illinois.
I am in South Fla, an not even the slightest signal at all, what lngsat has listed.
Their is 3 transponders that are active, music an talk radio, all vertical polarity, an they are strong here with 90 on quality.
now going back maybe 4 or 5 years I used to get Alaska stations on this sat, but no more, think they changed their beam pattern a wile back.
You say you can get talk radio on the vertical channels.
What are the transponder frequency, symbol, and audio pids for the vertical channels?
All Horizontal channels on AMC8 are spotbeamed to Alaska so unless you are in AK, Northern CA, OR, WA or BC you cant get them
Eastern Oregon here and its only 35 - 40%Q on the Mercury II. Think I am on the other edge of the spot. Its nice to watch the news. Lived in AK for some time and its just like old times watching it.
adding svideo or componet to the 905?
Satellite bleed over
