cant map in the new maps | SatelliteGuys.US
coinmaster32
916
14
USA
My old 920 has not been mapped in a long time, since the W5 sat is not in the sat list. I have to go to W5-500 to get the new maps, but how can I go to W5-500 if w5 is not mapped in the sat list?
point your dish at 105w. program g0 there and manually tune(options 6-7-7-8-1) frequency 1430.000 . let it sit and see if the new map downloads. if you go to lyngsat.com you can tune any digicipher2 signal on 105w by subtracting the frequency from 5150. try both polarities as sometimes the 4dtv recievers require the polarity to be opposite of what lyngsat lists.
crackt out,.
If your 920 does not have G0 then use G9. If it doesn't have G0 then it probably has been Master Reset. Follow crakt's instruction either way.
Switch, Method or Drawing of 2 GBOXes on 1 Mover???
Ding dong my dish is dead.
