Cant' record FX repeat Sons Of Anarchy tonight | SatelliteGuys.US
KAB
22,315
6,299
Fishers, IN
In the guide, repeat from last Tues. Can record everything before and after, but not it. Info says no info about the program.
Dish needs to update the system. On Oct 1st, the HDNet Movies and HD Theater info was only displayed for two programs then we read the FX or Nat Geo info, on the main guide. On the bar that comes up when you are quickly scanning one channel at a time, you got the no info message. Dish should have this fixed within a day (if history repeats itself). Also, the last poster is dead on, just manual record it.
For future reference, you could do a manual timer when that happens.
i agree there, it usually takes a while for the program guide listing to correct themselves for long term listings, i seen it happen when TeenNick (then The N) and Nick Jr (then Noggin) finally made the split on Dish Network after it split on other satellite and cable providers, also saw this happen when this dispute began and also saw it happen when Fuse was replaced by Palladia for only a couple of months when the dispute over Fuse began.
so manual time your programs on FX in the meantime.
I had that problem with my local RSN, in Cincinnati, so I did a check switch and then the system reloaded my guide and all the info came up.
FYI, SOA's last ep is being repeated twice, Sunday at 11:00p and Tuesday at 9:00p (right before the next new one).
If you are talking about where the EPG guide shows the show that is currently on and in the next time slot it says Information Not Available you can always initiate a check switch, by 6-1-1 on the VIP series, then back out and re-download the guide data.
Yeah I should have taken time to read the whole thread ^ wolfjc had it covered *L*
Why Is Dish Exec. Selling Stock?
