can't see cameras | SatelliteGuys.US
can't see cameras
dolaman
6
Recently, I had this hr20 5 lnb dish installed, I previously was using the 3 lnb oval dish, in which my input lines from the dish, went into a zinwell 6x8
multi switch, the out puts of the multi switch (8) of them each went to a diplexer (sat side) thru side to tvs to receivers, uhf/vhf side went to the out ports of a 8way 1000mhz splitter, the input side of the 8way went to
my modulator, so that I could see my front and rear doors on selected channels.
Now, this new flexiport multi switch , I'm told won't work with the diplexer and modulator setup that I have.
Can someone shed some light, or give me an idea of how I can see my cameras again?
Because of the different frequencies used with the 5LNB dish you can't diplex signals on those lines. It can be done, but I'll have to leave that to another member.
Comcast sportsnet philly
How the Receivers select sats & Transponders
