cant`t find 129 signal | SatelliteGuys.US
dish65 said:
I install a 1000+ system but i can`t find 129 signal
I have 110,119,and 118.
What i did wrong,please help me
Thanks:confused:
Did you remember to put up a dpsingle/dpdual for the side bracket to catch 129? If not.... Then there you go.
Otherwise check to make sure you're not using a 1k4 arm(has a wire exit on bottom)& that the reflector isn't bent.
Sent from my fingers.
if you have 118 you are pointed in the right direction, but the skew may be off
what do your signal levels look like?
are you sure you have line of sight to 129?
post a pic of the dish and the view of the sky from behind the dish if possible
Easy to connect to DPP44? Do I understand it correctly?
Whats going on with the 625 receivers?
