Captive Works 600 | SatelliteGuys.US
Captive Works 600
fta_8180
My First post so be patient, maybe this is too much info but here goes...
I just got a captive works 600s and like everybody is saying it's a user friendly receiver to wrok with.
My Setup is as follows...
18" dish with dual LNB pointing to the 119.
Special bracket that screws onto the the 119 and points a second LNB in the 110 direction (no need for 2 dishes on the house)
I have the 119 RG6 cable going to LNB1 on a diseq switch and a RG6 cable going from the 110 to LNB2 on the diseq switch. Then from the diseq switch to the Captive works 600 reciever.
Software version in 1.48 on the CW with the channel patch installed
On this same setup I have the 119 and the 110 going through a switch to a DP 301-13 atmega128 running in the basement with no problems and no channels missing!
But with the FTA I'm missing quite a few channels from the 110 bird (e.g. 175-BOOM) It either says "scrambled channel" or "Signal is weak". All of the "missing" channels is from the 110 bird.
I know the signal can't be weak because I'm able to get it from the DP301-13 in the basement.
Anyone having the same problem or have any suggestions to try to fix this...
no we aren't...and why you might ask?
BECAUSE WE AIN'T TRYING TO F**KING STEAL SERVICE
This is one of the most blatent hack posts I've seen in a while. Why dont you just put the subject of "I'm an idiot and I steal Dish Network...Please ban me Iceberg"
CLOSED
BANNED...that makes 33 now
DONE
(dipshit)
Positioning a Switch
Need help tuning in Fox video on G10R
