OTHER - CaptiveWorks 600s | SatelliteGuys.US
OTHER CaptiveWorks 600s
dav3bond
7
Sacramento
CaptiveWorks 600s does it still work? Ive had several receivers in the past and was hoping there is still updates and support. please help!
Still works for what?
That receiver is over 15 years old, so it would be good for most of the stuff on 97W.
What satellites are you after?
Well back in the day my sat dish pointed at the southeast horizon so I think the 110 and 119. but if its good still for 97W thats okay i guess.
So do I need to update software or just hook it up and turn it on?
valueWell back in the day my sat dish pointed at the southeast horizon so I think the 110 and 119. but if its good still for 97W thats okay i guess.
Or. should i just buy a new one and if so which one would you recommend as far as value goes?
AMIKO Mini HD SE no signal
OTHER 22khz Switches Not Working.
