Captiveworks and Transponders | SatelliteGuys.US
loyd
8
Hi,
I've finally figured out that my CW600 software doesnt really have all transponders listed by default. I would like to add ASN from Anik F1. From the Lyngsat site I found the following
Freq: 4060
Vertical
Synbol Rate is 810
For some reason it doest seem to pick up. I suspect that I'm reading something wrong, more specifically the symbol rate. Also does anyone know if the blind scan is just a placebo? Should blind scan find all the transponders?
thanks in advance
loyd said:
Hi,
Freq: 4060
Vertical
Synbol Rate is 810
I assume you have a C-Band dish?
and the symbol rate is 28346 (they have to be at least 4 digits) :)
thanks in advance
blind scan is vaporware. They "claim" it has blind scan but I have never got it to work
Tivo & FTA
LNB Position
