CaptiveWorks CW-800S | SatelliteGuys.US
magnoan
71
Hello.... I'm thinking about buying CaptiveWorks CW-800S, I will be using it with a HH100 motor, is there any problems with the USALS on that system, its key that i get a USALS system to work ?
Thanks ....
I'm using a cw600s with no problems. Usals works flawlessly, as does the diseqc 1.2.
I'm sure you won't have any problems if you set it up correctly. I'd like to know how
the blind scan works on the cw800s....if you don't mind, could you post your review... that is if you buy it.
Thanks.
Sat Calculators
Free Primestar Dish (South Stl, MO
