Capturing HD streams with a lesser computer | SatelliteGuys.US
timmy1376
698
Manhattan, KS
Guys,
Twinhan has a caputre tool on their website under the downloads that I used last night to capture a 1080i HD stream off of G11 with a computer that couldn't handle viewing the stream in ProgDVB. I captured a little over 18 mintues and the file size was 2.44 GB, which was about right for 9 GB for an hour of HD. The file format however is in a .dat format for which I am not sure how to convert it to anything else. Videolan Client (VLC) will play that dat file so it's fine to watch, but if I want to convert it, I am going to have to find another way.
This tool could also be used to capture any stream, including 4:2:2 non-HD stuff.
If anyone know how to convert that file, let me know. I am attaching a cap out of VLC to show you what I got.
I am not sure if this tool will work with any other cards.
tim
timmy1376 said:
Guys,
tim
It probably saved the original stream, but gave it the extension DAT, instead of TS or MPG.
What are you trying to convert it to?
Really anything. I would take it in mpg or wmv, or divx. I just wanna keep it in a smaller, downrezzed version.
I try changing the extension to .ts and using HDTVtoMPG.
All a *.dat is (in videowork) is an Mpeg. If you rename it *.mpeg or *.mpg, it'll play and work just fine as that. I often do that with VCD images; just copy the *.dat to the hd and rename *mpg, which Windows Media Player can play. If you want to convert from that file to Divx AVI, use VirtualDUB or NanDub. Both are excellent, free tools for video conversion which I use daily ;)
Neither changing the file extension or using VirtualDUB worked. I even tried to convert it using VLC but it crashed in the middle. Maybe it is the size. I tried Win. media encoder, TMPEgenc., VirtualDUB, etc.
What's wierd is that VLC will play it when nothing else will.
Does anyone know of a different free program that will just save the stream? This program is just too much of a hassle.
IA-13 C-band FTA AC-3 problems
LNBs?
