CE For 6/13 & 6/14 | SatelliteGuys.US
CE For 6/13 & 6/14
dfergie
Proud Staff Member
Staff member
HERE TO HELP YOU!
CE Announcement
Software Download Windows:
Friday, June 13, 2008 11PM - 2:30AM ET
Saturday, June 14, 2008 11PM - 2:30AM ET
Be sure to double check your full model number before forcing a download
HR21
HR21-100 - Status: Expected
HR21-200/HR21Pro - Status: Expected
HR21-700 - Status: Expected
HR20
HR20-100 - Status: Expected
HR20-700 - Status: Expected
Note:
  • Remember, this is an Early Estimate and things could change
  • If a model is not listed we do not have information one way or another
  • As we get more information, we'll update the list
Expected is greater than 75%
Possible is greater than 50%
Maybe is greater than 25%
Release notes for these CE versions will be available in the Cutting Edge Announcements forum when they are ready.
There are a couple of threads about the releases. None of them but this one says hr20-700. Is there a ce release for it this weekend? If so what is it.
Typically the HR20 & HR21 notes come late - sometimes right up until the release.
As soon as DirecTV sends them out - we'll have them up :)
Thank you Jason. I don't want to do a forced dl and loose the ce firmware. I guess that is what would happen if they had no release for my model. It would dl the current open release? Correct?
How to Force Download a Cutting Edge (CE) Release
Widget Suggestion Thread
