CEDIA-2016 PR: Sony Electronics Updates and Expands their ES Family of Audio-Video Receivers | SatelliteGuys.US
  • Thread starter Thread starter Ilya
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
Ilya
XXI Century Explorer
Staff member
HERE TO HELP YOU!
32,641
21,038
NE OH
Press Release
by Communications 09/14/2016, in Home Theater
New Models Address a Variety of Custom Installation Needs
DALLAS, September 14, 2016 (CEDIA Booth #3710) – Sony Electronics announced today the addition of four new audio-video receivers to join their current ES flagship model, the STR-ZA5000ES. Designed specifically to meet the needs of custom installers, the STR-ZA3100ES, STR-ZA2100ES, and STR-ZA1100ES provide the best installation quality. All of these new models, including the new entry-level STR-ZA810ES, support 4K HDR capability and incorporate both Dolby Atmos™ and DTS:X™ immersive audio.
“These new receivers feature our legendary ES build quality and are specifically designed by Sony based on feedback from the CI channel,” said Yukio Ishikawa, Director, Home Entertainment & Sound, Sony Electronics. “Their advanced audio and video performance make them the perfect complement to the emerging 4K UHD and HDR platforms and the ideal centerpiece for next generation home entertainment systems.”
ES Series Expands
Sony’s ES line of receivers are built for installers, inside and out. The ES series of receivers delivers the superior audio and video quality you expect from Sony and offers a suite of integration features for the custom installer: superior 4K device handling, ease of installation, third party certification, removable front panel, and multiple setup options. The ES receivers feature enhanced compatibility with leading control systems, intuitive web-based configurability, native HDCP 2.2 support and more. Sony’s highly regarded ES build quality features “Frame and Beam” full box construction that increases rigidity. When combined with the receiver’s off-set feet, this helps eliminate airborne vibration.
Installer-Friendly features
All of the expanded family of ES Audio-Video Receivers support network updates and include a multi-function Remote Commander that supports a variety of discrete operating codes. Also, all include Sony’s Auto Calibration technology, D.C.A.C. EX with Speaker Relocation. Utilizing a stereo microphone and 31 bands, D.C.A.C. EX compensates for less than ideal listening environments by closely simulating the sound field produced using optimally positioned and angled speakers. And a new feature called Phantom Surround Back provides a 7 channel surround experience with a 5 channel speaker configuration.
The STR-ZA1100ES and above models support ihiji, a cloud-based network management solution, and are compatible with most common controllers, including Crestron Connected. The STR-ZA3100ES and STR-ZA2100ES models can decode up to 9 channels.
Superior Sound Quality
The STR-ZA3100ES, STR-ZA2100ES and STR-ZA1100ES models include a full range of convenient features that address virtually every system integrator’s premium audio quality requirements. All of the new ES receivers are compatible with both Dolby Atmos and DTS:X and support a long list of legacy surround formats, including Dolby TrueHD and DTS-HD Master Audio. The receivers incorporate three powerful DSPs, which reduce noise and provide clear sound localization and ambience. These processors are mounted, together with a high-grade electrolytic capacitor, on the receiver’s power line to ensure an ample supply of clean power and optimal performance.
To further enhance sound quality, the new ES models utilize high capacity transformers with localized power supplies, low phase noise precision crystal oscillators, and sonically tuned audio grade resistors.
Advanced Video Quality
Each of the new ES models includes six HDMI inputs (except the-ZA1100ES, which has 5) and two outputs that provide full HDCP 2.2 compliance and supports the latest 4K 60p (4:4:4) Ultra HD content pass-through such as Ultra HD Blu-ray discs as well as video streaming in full 4K resolution and High Dynamic Range (HDR). It can also distribute both 4K video and multichannel audio simultaneously to two different zones. These new ES receivers are compatible with the new BT.2020 wide color gamut standard for future applications.
Additionally, the four new ES receivers can upscale video to 4K 24p.
Pricing and Availability
The new receivers are exclusive to the custom installer channel and with a 5-year limited parts and labor warranty. All four models will be available to dealers and the custom installer channel in spring 2017. Detailed specifications will be available in early 2017. The manufacturer’s suggested retail price and high-level specifications are as follows:
  • STR-ZA5000ES (current model), $2,799.99 msrp, 9 x 130w, 11ch Decode, HDMI (6/2), Dolby Atmos/DTS:X, HDR/HDCP2.2, 8 port switch (2 POE), Pre out, Aluminum panel, Crestron Connected, Supporting ihiji
  • STR-ZA3100ES (new in 2017), $1,699.99 msrp, 7 x 110w, 9ch + Phantom 2ch Decode, HDMI (6/2), Dolby Atmos/DTS:X, HDR/HDCP2.2, 8 port switch (2 POE), Pre out, Crestron Connected, Supporting ihiji
  • STR-ZA2100ES (new in 2017), $1399.99, 7 x 105w, 9ch + Phantom 2ch Decode, HDMI (6/2), Dolby Atmos/DTS:X, HDR/HDCP2.2, 1 Ethernet, Crestron Connected, Supporting ihiji
  • STR-ZA1100ES (new in 2017), $999.99 msrp, 7 x 100w, 7ch + Phantom 2ch Decode, HDMI (5/2), Dolby Atmos/DTS:X, HDR/HDCP2.2, 1 Ethernet, Crestron Connected, Supporting ihiji
  • STR-ZA810ES (new in 2017), $799.99 msrp, 7 x 100w, 7ch + Phantom 2ch Decode, HDMI (6/2), Dolby Atmos/DTS:X, HDR/HDCP2.2, 1 Ethernet
Sony is exhibiting at the CEDIA Sony Booth #3710. For more information and images visit http://www.sony.com/news/.
