Hello all! I am a somewhat new directv customer and am having a problem. I'll do my best to describe the situation.
My zip code is 65611. Blue Eye, MO. Some channels will be fine for about 10 seconds, then search for signal, then be fine for 10 seconds and just keep doing this. Local channels are fine. No problems with locals. The channels I notice the most that have the problem are all the discovery channels, FX, and some others. If you need the exact list of channels that are having problems, I can get it, it will just take awhile...
anyhow, here is the research I've done so far. all transponders on sat 101 are 95 or above except 12, 18, and 26 are at 0 which i have read is ok. 20 is at 88 and 28 is at 77.
sat 99(c) 1-14 91 or above 14-32 N/A
sat 99(s): 1 at 53, 2 at 92, 3 at 56, 4 at 0, 5 at 55, 6 at 85, 6-14 N/A, 15 at 79, 16 at 98, 17 at 76, 18 at 85, 19 at 97, 20 at 98, 21 at 95, 22 at 95, 23 at 91, 24 at 97, 25-32 N/A
sat 103(s) 1-6 at 0, 7-14 N/A, 15-24 at 0
sat 103(ca) 1-8 N/A, 9 at 95, 10-11 at 0, 12 at 91, 13-18 at 0, 19 at 95, 20 at 95, 21-24 at 0
sat 103(cb) 1-2 at 0, 3 at 96, 4 at 0, 5 at 95, 6-7 at 0, 8 at 95, 9-10 at 0, 11 at 95, 12-13 at 0, 14 at 95, 15-32 N/A
sat 72.5 1 at 0, 2 at 96, 3 at 96, 4 at 97, 5 at 95, 6 at 0, 7 at 96, 8 at 100, 9 at 95, 10 at 97, 11 at 97, 12 at 0, 13 at 97, 14 at 96, 15 at 0, 16 at 100, 17 at 96, 18 at 0, 19 at 97, 20 at 89, 21 at 98, 22 at 100, 23 at 98, 24 at 100, 25 at 97, 26 at 97, 27 at 98, 28 at 76, 29 at 98, 30 at 100, 31 at 96, 32 at 100
NOW, I've noticed that when I go to the signal meters on 103(cb) the transponder 1 will alternate every few seconds betewwn 96 percent and not acquired. same with 2,3,4,5,6,7, and some of the transponders on 103(cb) that I listed above as having a strong signal I can not get to show any signal in the signal meter at this point.
Needless to say I am seeing patterns as I type this. It seems that there are lots of inconsistancies in the signal strength on the transponders on the 103(cb) satellite.
SO... any help would be greatly appreciated. If you need any more info from me, please don't hesitate to ask. I will say that this receiver is on a rather long cable from the dish. I did try to move the receiver to another receivers location and plug it in and it seemed to work fine... I just don't know why only the 103(cb) satellite is having problems. You can probably tell it took some time for me to get all those transponder readings. I'm serious about getting to the bottom of this... Step Brothers was on FX and I really wanted to watch it!!! I love that movie but it kept going to searching for signal every few seconds.
thanks in advance for any help I can get!
