Certain HD Channels Low/No Signal | SatelliteGuys.US
Boondockbill
218
HDN
HDNM
UHD
always blacks out and says searching for signal
other HD channels are fine.
Tried repositioning the dish to no avail. What's up?
Had the same problem here. Need the neighbors to go away so I can create some storm damage to their tree blocking one of the sats. In addition to those i lost ABC-HD since the trees came out with their leaves.
Having the same problem. All of a sudden I can't get good signals on Sat B.
Not getting ESPN HD or Discovery HD. The only two HD channels I really watch.
Does any one know where I can get the listing of what channels are on what transponders? I've seen it in the past but can't seem to find it.
Hope when new birds are up that I won't have this problem. All signals on Sat a are 90 or above. Sat c is up and dowm depending on the weather.
Sounds like you need a dish tweaking; all my birds are currently hitting at 90 or better on all transponders, on all 3 satellites.
Have many trees surrounding my house, is it possible that new leaves on trees could be causing my problem?
Thinking about upgrading to HD
Resetting DCT210
