No way of knowing till game time.With Genie 0x0929 going NR, do they start the next cycle with a new feature or will it be mo' UTH?
Look up in the stickys ..Where did you see two different downloads Jimbo? I only see the one low risk customer candidate.
No My Directv is common ...Well, I'm running CE on HR23-700, and My DirecTv is empty again, just as it was a few weeks ago when I first went CE on my HR34. The playlist problem ended up being someone hit the Yellow button and choose to only see the local playlist in the Recordings.....
But, even the HR24-100 even has the problem of an empty My DirecTv after the CE.
Dumb question but is the playlist set to local or all?I'm trying the CE on my non Genie HD DVR's. I have an HR23-700 that can SEE my networked DVR's in Status, but, will not show any recordings in the Playlist. However, IT'S recordings are available in the Playlists of the Genie and the other HD DVR. I've reset my router, the DVR itself, the Genie and other DVR, my network switch, and did a Network setup on the offender, pulling an IP address and testing getting a good result on Network Connected and Internet Connected, and Share and Delete from all rooms.
Still, it only has it's OWN playlist.
So, I figured why not. I'll pull the CE on my other 2 units, and see what happens.
The offender is an HR23-700 and the other is an HR24-100.
Yes, losing the Guide would be a HUGE Issue !I saw that the first time I did the CE a few weeks ago on my HR34. It never came back. Then, 2 weeks ago I did the CE, and it was back immediately. But, it't not like it's a big loss. It's not something I really lose. If I were to lose the guide or something important, I'd be upset!![]()
When you hit List, then the Yellow button, you get the following :Dumb question but is the playlist set to local or all?
Hit list then the yellow button then filter by playlist and ensure its set to all.
Jimbo do you have multiple dvr's on your account? This option will only show if multiple dvr's are found on the same swm network.When you hit List, then the Yellow button, you get the following :
Playlist Options
Mark Programs to Delete
Set Programs by Category
Change order of Playlist
Open/Close all
Ahhh, yes I do , but I do not use them that way.Jimbo do you have multiple dvr's on your account? This option will only show if multiple dvr's are found on the same swm network.
Limited time offer
