change recording priority results in duplicate recordings | SatelliteGuys.US
sportflyer
31
4
Vancouver, WA
I was changing my upcoming program recording priority by moving programs higher or lower . After making the changes I noticed that I ended up with duplicates of the programs I moved. For example if moved "Blindspot " from #16 to# 25 down the priority list , I ended with Blindspot in both slot 25 and 26 ? This happened to any program whose priority I changed. This never happened before. I ended having to delete everyone of the duplicates created when I moved the programs . Is there a bug in the program management screen?
I haven't seen that one yet ...
Do you use an OTA antenna as well ?
I have had it change the selected Recording channel before ... such as, I set it up to record the OTA channel and a few minutes later it would remove the recording from the OTA and move it to the Sat supplied channel ...however, that was fixed when the ALL Channels issue was fixed.
directv 4k
Missing Recordings
