The local antenna supplied by Orby will not pick up my local channels. Can I remove this antenna and install my own higher power and antenna.
Splitter is with all ports power-passing and possibly diode steering?I did not use the antenna supplied by orby. I have an 8 bay bowtie that I already had installed. I have a dedicated RG6 cable in every room already. I put a diplexer on a short jumper at each orby receiver.
There is no diplexer at the dish.
The dish is split with a 4 way power pass splitter to my 4 orby boxes.
Works perfectly.
Sent from my SM-G950U using the SatelliteGuys app!
A conventional satellite+OTA diplexer is just fine (power passing on the SAT side only). You typically don't want to be sending LNB power from the Orby receiver(s) to the OTA network.Splitter is with all ports power-passing and possibly diode steering?
I was hoping to remove the Orby antenna install my 125 mile (?) antenna. You guys snowed me With with talk of duplexers ect...That depends on what you mean by "my own higher power". If you're planning on using a pre-amp (an amplifier mounted very near the antenna), you'll need to wire that independently from the Orby cable.
Oh I realize this;A conventional satellite+OTA diplexer is just fine (power passing on the SAT side only). You typically don't want to be sending LNB power from the Orby receiver(s) to the OTA network.
If a pre-amp were used, the power inserter for it should be on the OTA network so it would not energize the satellite network. Some pre-amps use 48VDC power inserters.
Sorry about the information overload.I was hoping to remove the Orby antenna install my 125 mile (?) antenna. You guys snowed me With with talk of duplexers ect...
It shouldn't require anything over and above the standard Orby splitter (all ports passing DC). The OTA network is protected from LNB power by the diplexer(s) and the OTA network can't pass power (in the event that you're using a pre-amp) to the satellite network for the same reason.But I was specifically inquiring about the 4-way satellite splitter used in "truckracer's" Orby setup. Which is a bit different than the standard installation.
Limited time offer
