How do I change the ZIP code on my HR21-200 ? I guess the installer put the wrong one in. I've looked all thru the menus and can't seem to change it.
Why do you think the zip code is incorrect? There's a couple places where you can put it do it would help to know what area is the problem.
If I push menu and go to settings/setup it shows the wrong ZIP on that page. It's only one digit off, but it's wrong. It says system setup at top of page.
zip also determines your OTA info in guide
Limited time offer
