Changing Zip Code - HR20 | SatelliteGuys.US
gadgtfreek
22,105
865
Lower Alabama
When I moved from Sc to Va, my zip in the box did not change. When going into setup, the Zip Code is 29445, while the Primary Local is correct at 23188.
Where in the world do I change the 29445 to 23188, havent located it.
It could be in the satellite setup (probably) or the active weather application, both have places for entering a zip code.
So should I rerun the setup? Or is it not a big deal?
Im just thinking about if they ever get the weather updates going, I may not get the correct info.
Where is the active weather?
I don't see any harm in rerunning satellite setup, as long as you answer the questions correctly.
For weather press ACTIVE on the remote. , The select WEATHER then select SET ZIP.
Thanks. I just found Active, never used the button before :). I changed my weather zip, but guess Ill rerun setup to change the other.
99c possible problem?
Obtaining AU9 dish
