CHANNEL 481 & 482 NOT AVAILABLE ON SD RECEIVER | SatelliteGuys.US
kalin21
41
tx
I am trying to watch these channels now for soccer, I can watch on my HD receiver but my brother in the bedroom has SD receiver and is not seeing this channels on the guide...what is the problem here
some channels are only in HD...
on your HD receiver you can change it to "Show all channels"....if 481 shows up only once then the channel is only in HD and SD receivers cant see it
just looked and those are only in HD
I just went and told the HR34 to "show all channels" and it only shows one 481,482,483,484. Stations like that normally would have the -1 for HD but since they are only in HD its not needed
Are these channels not free anymore? I can't tune to them on either of my receivers, both HD. I can see 481-1, etc in the guide, no "plain" channel (480, 481, etc). When I select or manually tune to 481-1 it says "channel not available."
Help
HD for an RV Using a Portable Antenna
