Channel IDs needed | SatelliteGuys.US
Channel IDs needed
iafirebuff
4,394
8
Waterloo, Iowa
OK, I have been setting up my titan tv sked, and also programming names into the Fortec. Anyway, I have a few stations that I need some IDs for:
I have the following that shows up on the receiver:
KDEV ABC CH 8
KDEV-LP (RTN)
Are these ID's correct?
And I have a few that don't have IDs:
12103 v 2220 It is an ABC station
12114 v 4444 It is a UPN station
RADIO:
11800 v 26657 APID 297
11800 v 26657 APID 47
11800 v 26657 APID 294
Does anyone know the correct IDs for these or a link to find them? THANKS in advance!
KDEV-LP doesnt work on Titan TV. It tries and logs it as KKTU (now KDEV 33)
signal on 12102 V 2222 is KWTO 2
signal on 12114 V 4444 is KFDF 10
OK, I went to Lyngsat, and found that KDEV is an ABC, is it also a RTN Station too? KTWO, and KFDF are the others. Lyngsat says KPBI a fox is on there. Can anyone confirm that they can get KPBI? I can't get it. THanks!
I have KDEV and ABC and I have KDEV-LP that is an RTN
KPBI is scrambled
Yes there is KDEV & KDEV-LP. KDEV was KKTU 33 and is licensed to Cheyenne, WY. KDEV-LP is Aurora Colorado and is channel 39.
You can have a TV and a LP with same call letters...KQUP is the same. KQUP is licensed to Pillman, WA and is for Spokane but doesn't cover it. SO they have KQUP-LP licensed to Couer D'Alene to cover that.
IA7 Question
How to work Satellite meter?
