FOR SALE - Channel Master ATSC HD Modulator (HDMI to Coax) | SatelliteGuys.US
FOR SALE Channel Master ATSC HD Modulator (HDMI to Coax)
cpalmer2k
1,098
696
United States
The Channel Master ATSC HD Modulator is a professional grade encoder/modulator designed for commercial and residential installations. The ATSC
HD Modulator converts a video signal from HDMI format to a Digital ATSC (Coax) format.
This modulator is like new, having never been used. I opened the box and took it out to take a look at it once, but never set it up or used it, because I ended up getting rid of the device I was going to use it to distribute the signal from. Sells for $299 on Channel Master's website.
Asking $225 shipped.
The digital channel is user-selectable (2-99) then output via the coaxial RF output on the back of the device. Digital channels that are generated from this device can be scanned and tuned by most TV and set-top box ATSC/OTA tuners. Equipped with a front panel display and menu navigation buttons, settings such as RF channel number, virtual channel number, and RF output level can be configured without the use of a computer. The modulator can also be managed over a local network via the built-in ethernet port.
FOR SALE TiVo DVR for Antenna (OTA) with Lifetime Service and 2TB Hard Drive
