Channel Master, DVB-S2 QPSK/8PSK, MPEG4, Receiver Compatibility | SatelliteGuys.US
dsmith0429
470
195
Lake Placid, FL
Is there any receivers that supports DVB-S2 QPSK/8PSK and MPEG4, that is compatible with Channel Master by #C version 1.20.3? Also, is Channel Master by #C version 1.20.3 the latest version? THANKS!
I am not aware of any current model receiver that will directly load a file outputted by this firmware.
You could output from ChannelMaster as a generic bin type and import into Mediabox Editor Studio then export to current model STBs. I have transferred satellite/transponder/channel lists from a GEOSATpro DVR1100c to a microHD using this method.
Would need to fire-up another computer to check the version, but not many changes between versions except to change supported receivers and the ad rotation (which I have deleted).
What Happenned to Reelz and OneWorldSports in Galaxy17 (91W) ?
APID, VPID Question.
