Channel Numbers | SatelliteGuys.US
Channel Numbers
chrisb83
SatelliteGuys Guru
121
San Francisco Bay Area
I have a question and I'm sure this has been discussed at sometime or another but I can't seem to find a thread that answers my question. So here it is, Why does E* have so many duplicate channels? Some channels are on the guide under 3 different channels. I have set my favorites to not have this problem but it seems to be getting more disorganized than ever before. Thanks . Oh FYI Charlie Sucks:D
Every channel is only located at one location, many of them are mapped to another location to make them easier to find. Some are locals, some are in the superstation package, some are grouped with their sd channel. They do not take up any additional space when they do this. If you don't want to see the channels in so many locations, you can either shut off the mapping feature (located in the Local Channels under the system setup) or you use the hide lock channels under the Locks menu.
Thanks that helps.:) I was just tired of seeing duplicate channels on my Sub Guide.
Problem with "Point Dish"
HD Only Pack and RSN's
