channel VTV4 changer | SatelliteGuys.US
popup2005
2
hello.anyone help to get channel VTV4 FTA receiver BEC 2000.because channel VTV4 changer to 11996-22000 H,i try to reset to manufactory defaul efter it i can not get any channel back, please help me out thank you
sksatellite said:
You need to enter everything again into the receiver. Hope you know how.
we know that but how to do it that is the point If you can help Please ! if not don't tell us the Stupid Thing like that
sorry
I just found out here is you can try Poppup2005
if yours systems is the same with Mine
go LNB Port set up
LNB INDEX =1
DISH TYPE =FIXED
LNB TYPE =KU BAND
SATTELITE =TELSTAR 5
LOW FREG =5150
High FREG =10750
NONE
NONE
0/22K HZ =22KHZ
NONE
Go to Channels searching and do the same thing hope it hep you
sorry
With lots of different recevers out there, we can't give you step by step instructions....thats what the manual is for :)
But if the transponder is not in the list, then you have to manually add it. I don't have a BEC but most of my receivers (and I've used about a dozen of them) have a trandsponder list that can be edited.
Rtpi quality issue
EchoStar 1,2
