Channelmaster antenna | SatelliteGuys.US
butes181
2
usa
Hi, Is it better to mount, without choice of position, the larger channelmaster 3671 or use the smaller 3679 antenna and have alittle room for positioning before mounting? Length on 3671 is 173" and on 3679 is 122". To be mounted in attic.
Thanks smart people.
If all your stations are in the same direction, the larger antenna mounted stationary is best, other than putting it outside where it can breathe.
How do you know how many splitters you can use
How can I find out which HD OTA channels are available in my area?
