Channels change on their own! | SatelliteGuys.US
bigboblargerobert
2
oregon
Greetings! I have a DPS 322 operating 2 TV's. Recently TV2 has started changing channels on it's own, setting timers, scowling through the channel guide etc. I shut off and disconnected a home theater located near by thinking it was affecting this.....nothing. I've switched to another IR remote.... no change. It's actually kinda of entertaining when theirs nothing interesting on, but I'd like to fix this. Any ideas?:confused:
It definitely is what garys said. Same thing happened to me when my neighbor got dish. i changed my remote code and it fixed the problem
You're also changing the neighbor's channels and they might not find it so entertaining. Your manual tells how to change TV2's remote address.
Limited recording question
Happy after install
