Do these drive the actuator? They have a selection fir satellite up and down but i can't figure out where they would tie the wires in on the back. Thanks
Looks like they do - there's a whole section in the back with push connectors for the actuator (labeled "MTR"), the sensor and the polarotor (if using one)Do these drive the actuator? They have a selection fir satellite up and down but i can't figure out where they would tie the wires in on the back. Thanks
That receiver does move the actuator, you should have 4 wires coming from actuator,3 wires from the feedhorn. If you want to check it. Connect the actuator to the receiver before you put on dish. However, it's not that simple, if you don't know what I mean don't do it. If you do only hook up motor wires, and hold the end of actuator, or it will lose count.Looks like they do - there's a whole section in the back with push connectors for the actuator (labeled "MTR"), the sensor and the polarotor (if using one)
Limited time offer
