Negative not with NexstarCharge and next hope KC gets it on FOX4KC.
Charge! Will not launch on WADF when Nexstar takes over that Station from Tribune.Could you elaborate?
I'm sure you meant WDAF.Charge! Will not launch on WADF when Nexstar takes over that Station from Tribune.
Charge! is a Sinclair property but WSBK is a CBS-owned station so is it not possible that a Nexstar or Tribune channel might carry it?
The distribution of channels in the KC market is really funky. Rabbitears.info says their ABC is 1080i.
probably due due local news cameras in 1080i
All of the Disney properties are still 720p. These inlcude (but are not limited to) ABC, ESPNs, Disneys, Big Ten and SEC.I think it is 1080i. Only Fox still uses 720p, correct?
I suspect that it has more to do with the state of compression and multiplexing art concentrating on 1080i.Must be certain trades off on video format and quality.
TBD is a Sinclair property so it isn't surprising that it is on Sinclair stations.Yes but WDAF Fox4kc has TBD that's on Sinclair stations.
Limited time offer
