Cheapest Way to Integrate Legacy LNB's with Dish 1000 ? | SatelliteGuys.US
Stargazer
16,568
340
Western WV
I have a lot of legacy lnb's and was wondering what the cheapest way I could go about using those on a Dish 1000. I know that you can cascade a legacy twin with a sw-21 switch but is there no way to connect three single legacy lnb's cheaply? Can you cascade two sw-21 switches?
I know that DP and DPP lnb's/ switches are not compatable with each other. I just thought that there might have been something that I have not thought of that someone else may have done to make something work. If I could get SW-64 switch cheap enough then that would be the cheapest route it looks like. I don't like the power inserter for the 64 switch though.
and if you need four satellites, you can cascade a SW64 with SW21s between it and the receiver (except for the port with the power inserter)
OTA Electronic Program Guide
dish 6000 HD rec.
