Check Switch Error | SatelliteGuys.US
Check Switch Error
utcheme
10
When I perform a check switch.... it detects the switch but no satellites are detected and it says "switch error". What does this mean?
Basicly the receiver is seeing a switch but no signal from that switch. It probably means the dish isn't aimed correctly.
Where are you - is there snow on the dish? Moose in front of it? You get the idea, is anything blocking the dish?
moving dish hd receiver to a different hd tv
TV2 coax only will output TV1 signal
