Is that when you are on a date, and you realize the person you are with is even worse than your ex ?Chick switch error
Is that when you are on a date, and you realize the person you are with is even worse than your ex ?![]()
It is due to the fact that your installer did not install a good DPP LNB. I had the same problem and called dish back out and all is good. He even peaked 129 wich was a miserable 50 before now at about 63 for the lowest TP.
Limited time offer
