Why does my Hopper(2) run "check switch installation" (058) and then have to find the signal every single morning when I turn on the TV? (Takes about 5 minutes to complete). I have been working with Dish and they sent me a new Hopper which didn't fix the problem. When I went through the installation of the new equipment, it "failed installation" during the "check switch" portion. I was able to finish installation by unplugging the receiver to get past the failed message. I get great reception and there doesn't appear to be any issue with watching TV other than the morning switch check. When I look at the Switch Status under Diagnostics, it looks like Tuner 3 is OUT (red Xs for all 3 satellites). I think this is because I have a Hopper without a solo node but I have had this setup for over a year and my "check switch" problem only started about a six weeks ago. The problem did coincide with relocating from Florida to Washington. Also, when I select Check Status under diagnostics on my receiver, it will not complete. It gets stuck at 66%. Where do I go from here? At this point I believe it must be the satellite (Trav'ler Satellite) and Dish doesn't serve the RV community (Dish Anywhere).
