Check Switch Snafu | SatelliteGuys.US
Check Switch Snafu
StormGuy59
3
San Antonio, Texas
I have been trying to get a 311 receiver to lock-on in my motorhome which has a single LNB antenna (Winegard DM-RM46). At one point it almost locked on to 110 but failed. I have used a VIP211K in the motorhome and it worked. I ran the check switch test and it indicated there were less satellites available and then a box indicated if I wanted to save the new info which I did. Now the check switch function indicates no satellites available. All X's in all boxes. Is this something DISH will have to reset for me?
Try and run the check switch test again. We had an Up-link center go off line and it just was resolved. Please let me know and we will go from there.
What do you have 311? VIP211K.
You should never run the Switch Check unless you are real sure there is a satellite in the view of the dish. I have never taken it down to all X's. I have always recovered from 2 X's out of 3.
Another dishonline annoyance
Missing RSN after switching packs
