Chicago 61.5 spot beam coverage | SatelliteGuys.US
  • Thread starter Thread starter ka1z0ku
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
ka1z0ku
95
Chucktown,SC
I have been looking for a reliable (and readable) map showing the coverage of the 61.5 spot beam which carries the Chicago, IL HD locals. So far everything I've found on Google is just terribly unhelpful. The best map I've found so far shows spot beam footprints of the entire U.S. and, as you can imagine, its VERY difficult to determine the boundries of the beam I'm looking for.
Essentially, I need to know how much of central / southcentral Illinois is covered. So thanks in advance for any and all help!
Cannot access Dish on Demand after software update
Acutrac 22 Pro & Dish network DishPro Twin
