Chieta Diseqc Switch Question | SatelliteGuys.US
fred555
Pub Member
7,980
7,031
77W
I need to order some spare Chieta diseqc switches. Are there fakes out there?
The reason I ask is, here are the ones I have now:
The vendor I bought mine from is sold out. There is another vendor that sells these:
Were there different styles?
Which one is real? The second one does not look right.
The first one came in packaging like this:
How do you spot a fake?
They both look like Chieta switches. The larger one is their lower loss version. Seesat made a similar switch in both the small and larger lower loss versions. I have used the larger versions of both the Chieta and Seesat switches and have not noticed any difference in them. I have not used the smaller versions of them. (have only used them in simple switching uses and not in complex cases with motors)
Reactions: fred555
The lower loss version being 1.5 db as the first picture is labeled?
I just also noticed the second one is 3db insertion loss.
I did not know they made two versions, Thanks.
thank you very much for pointing that out Larry1 :) i'll bet maybe 1% of current fta people realized that (I certainly didn't). that 1.5db of extra loss for nothing could make for a non-watchable program.
Reactions: fred555
I used to think Chieta switches were the absolute best, until the last time I ordered some. They came in packaging like that shown in post #3, but in this day of color laser printers it would be pretty easy for a counterfeit maker to duplicate the original packaging rather closely. The ones I got had weird problems; on one port #4 was dead and on a couple of the others I was having weird issues with interference in the signals, which I can't say with 100% certainty was attributable to the switches but we had a lot less trouble after I switched to some Davey GDSW41's. Since I got the Chieta's from a seller on eBay they may in fact have been fakes, and then again it's possible that the interference issues subsiding about the time I changed the switches was coincidence, but still at this point I would not spend the extra money on Chieta switches unless I could get them from a reputable dealer that offered a warranty.
Those switches were just one of the purchases made for the satellite backend project that were later regretted. But I am not saying that all Chieta switches are bad, in fact I used my original one for several years without any problems whatsoever, which is the main reason I thought staying with that brand would be a good idea.
Ever consider getting the Amiko switches from fridgeFTA? I'm happy with what I've gotten from them.
Reactions: fred555
Thanks for the suggestion, I think I am going to order a few.
EDIT: Just ordered two.
Automatic Volume Control
Newbie, Polish Dish for Dad
