China unbranded FTA receiver | SatelliteGuys.US
kentucky joe
13
kentucky
Looking for a pdf or video on a China unbranded FTA receiver. The menu looks like a Sathawk PVR200 HD receiver. I can't find any thing on that one either. Here is some specs on it.
  • HDMI 1080p FTA PVR DVB-S2 HD TV Satellite Receiver.txt
If you haven't already bought one you might want to reconsider purchasing. Your text file of the specs includes the following line:
License: Optional DTS, Dolby Digital, Dolby Digital Plus, RM/RMVB, Divx License.
That means that any channel with Dolby Audio (and there are quite a few) will give you sound problems. You will have not sound unless you connect the receiver to an external Dolby decoder and in some cases I have read that that didn't work either. Best to avoid if possible. Read more on these here (long read but worth it if considering these, post 66 in the thread is where the sound issues are first mentioned): http://www.satelliteguys.us/xen/posts/3610875/
Thanks for the reply
I was looking for a user guide or setup manual of some kind to tell me how to setup a motor in the menu the one they sent isn't any help the only one I have seen that looks like the same menu online is the sathawkpvr200 receiver there might be others I might be able to look at that video or pdf guide if anyone has one.
thanks!
Somewhere 'in there' should be a setting for your Lat & long to be used with USALS. Otherwise you'll be stuck with using DiSEqC to move your motor.
I'd keep 'looking around' in the menus, as it's gotta be there somewhere.
(maybe you have to set a satellite to USALS before 'it' appears(?)
SpaceX Launch set for Sunday Jan. 17, 2016
HH120 position counter failed?
