Chopping songs too quick - need configuration setting guidelines | SatelliteGuys.US
jhand_us
8
I'm having issues with songs recording only partials of songs before the software thinks the song is over and cuts it off before it's captured it all (on some, the last 1 min is lost). I've checked the logs and the rest of the song is showing up as a second song and ignored as a dup. I've looked at the FAQ and user guide but I can find specifics on how to solve this issue. I'm playing with the song change delay and record buffer to see if that makes a diff. (up and down the values).... no luck yet.
Experts, what should one do to fix this and is there better docs somewhere (anyone have guidlines for configuration menu?)? *or* is it XM sending data that is confusing Recast into thinking the song is done before it really is? :eek:
Thanks in advance for any help.
FYI: I've used older versions of TimeTrax without this issue... it only showed on v1.4.
Hi,
This was an identified bug in 1.4 and we have corrected it in the next version.
This was something coming from the XM stream that we adjusted the software to accomodate for.
Derek
thanks - looking forward to 1.5! I love the product overall.
FYI: I set song change delay to 200 and record buffer to 500, it appears to be better - only one day of testing however.
The new beta is available now.
Please visit our site and install it. I think it should help with your issue.
Derek
What Is Raw Format
Unable to control output device for audio
