Circular? Linear? LNB feeds on Lyngsat | SatelliteGuys.US
This is a Linear satellite, you can tell as it uses H and V polarization.
Circular polarized satellites use L and R polarization. (L=H R=V)
So a standard KU LNBF should work, happy hunting!
most satellites are linear (C & KU band) with the exception of the following
Dish 61.5, 110, 119, 148
ExpressVu 82 & 91
These are Circular, so you need a different LNB
The encryption needs to be DVB to pick it up. DCII and others won't work :)
NTSC is analog
GeoSat .4 Linear LNB Any Good?
87W & 93W on single dish?
