Circular LNB For 118.7 W | SatelliteGuys.US
procyon
4
I have a motorized 36" dish, which I control from a computer. My present LNB only receives 12.2-12.7 GHz. I'm looking for a way to receive 118.7W without adding any switches. Is there a circular LNB out there that will receive the entire range that 118.7W/119W transmits (11.7 - 12.7 GHz)?
Thanks for the reply, Claude. If the 105 LNB works out, would you post the details of your modification and the range of transponders you are able to tune?
NFL HD Problem
1000.2 self-install for Pac NW (long)?
