Clock Display? | SatelliteGuys.US
Clock Display?
minskerm
4
I'm a new to Dish having switched form D*. On the D* HD Tive you could display a digital clock in the lower right of your TV by entering on the remote SELECT,PLAY,SELECT, 9, SELECT. Is there anyway to do same with the 622? It's the only thing I really miss.
I could finally get rid of my VCR if Dish would put a clock on their receivers!
So...the answer is...NO. But, if you hit the CANCEL button, it brings up the banner which has the time on it.
Try putting a clock near your set. I have battery operated one on top of mine. Eliminates any chance of burn in and is less distracting.
I wish Dish Network receivers could be programmed to add certain functions on the screen while you watch tv like channel number, clock, etc. Maybe there is a device or box out there somewhere that you can connect to a television to add certain things to the display. I know they had this for those that wanted caller id on their tv screen. Maybe there is something one can connect from a computer to program it or something.
how about an anti-aliasing nearby-pixel-extrapolating feature that would get rid of the network/channel logos in the corner. I would buy that one.
Upgrade to 622 in Indy
DVR510 Remote Problem
