Club Dish, what if 7 Referals- do you get 6&7 later? | SatelliteGuys.US
ScottChez
1,651
142
I search through all the club dish threads.
I got 7 regerals (handed out all my cards at work).
The system limits you to 5.
After the 5 referal credits all all done showing on my bill, will there computer then grant
6 & 7
Or am I just out of luck for anything after 5?
"you will not get credit for anymore till some drop off."
So after some drop off the other ones will kick in or do you have to start over?
Ok, now if you read the fine print from Club Dish, it states 5 referals per calendar year. So, you should still get new credits, even if you are maxed out at 5 from the previous year.
Since its a new year, has anyone done this and seen if this is the case?
no thats not the case.
if you activate one in June then you calendar year starts in July and runs till next June then the card will drop off and give you another slot you can activate.
$200 and dvd player to drop Dish
Sea-Launch Update
