whitewolf8214 SatelliteGuys Master Original poster Pub Member / Supporter Lifetime Supporter May 13, 2004 40,379 799 Space May 12, 2011 #1 Is there a code to do a manual update for hr 21/200?i have an hr 24 and the code is 02468 but my neighbor has an hr 21 and was wondering what the code for the hr 21 is ty for any replies and help
dfergie Proud Staff Member Staff member HERE TO HELP YOU! Sep 8, 2003 105,541 10,126 West of the Pecos, between White City and Roswell May 12, 2011 #2 Same for all of the H /HR's
whitewolf8214 SatelliteGuys Master Original poster Pub Member / Supporter Lifetime Supporter May 13, 2004 40,379 799 Space May 12, 2011 #3 dfergie said: Same for all of the H /HR's Click to expand... I tried that code and it didnt work to do manual reset tyvm ill try again on his receiver
dfergie Proud Staff Member Staff member HERE TO HELP YOU! Sep 8, 2003 105,541 10,126 West of the Pecos, between White City and Roswell May 12, 2011 #4 Try the red button reset?
Jimbo SatelliteGuys Master Lifetime Supporter Cutting Edge Jul 14, 2005 70,078 8,435 NW Ohio - Buckeye Country May 12, 2011 #5 whitewolf8214 said: I tried that code and it didnt work to do manual reset tyvm ill try again on his receiver Click to expand... It takes timing, you may have waited a bit to long to put the code in.
dfergie Proud Staff Member Staff member HERE TO HELP YOU! Sep 8, 2003 105,541 10,126 West of the Pecos, between White City and Roswell May 12, 2011 #6 And you have to do it (or it seems like to me) with a rhythm.
charper1 Bourbon Tester Supporting Founder May 18, 2004 18,442 6 I'm Nationwide May 12, 2011 #7 reset and right when it boots and you see blue front panel lights you can begin a even steady entry of 0 2 4 6 8 on the remote
