Colored circles next to daily schedule | SatelliteGuys.US
Boobie1998
SatelliteGuys Guru
133
Pennsylvania
Hi all,
Does anyone know what's the color difference is on daily schedule timers? There's an icon next to the recording. 1st ones blue, 2nd show is green and third is showing purple.
It tells you which tuner is recording the show...not sure which tuner has which color but if its 3 different colors it means 3 tuners will be used
It's more of a one tuner in use, two tuner in use and all three tuners are in use to record indication rather than a specific tuner indication.
Yes, blue = 1 tuner, green = two tuners, violet = 3 tuners. There is no particular tuner preference.
Also, this is the number of tuners in use (for recording) at the start of the event; not necessarily for the duration.
Just received S207 this morning. What did it fix?
Is there a way to save PTAT recordings remotely?
