Combining Dishes | SatelliteGuys.US
Combining Dishes
beakor
18
I currently have a phase 3 dish mounted on a tree (the only line of sight for all three sats). I had a at-9 dish installed to pick up the new spotbeam. He put it on my roof. I have no line of sight for the 119, it finds the others. Is there any way to take the 119 from the phase 3 dish via a signal combiner? Could you run 2 cables to the ports on the side of the ka/ku lnb (where the 110/119 attaches)? I have a feeling I am just sol.
The Ka/Ku dish is not compatible with other types of LNBs, don't plug anything into the 110/119 ports of the main LNB head except the specific LNBs that come with the dish. Someone mentioned using a second Ka/Ku of the same type just for 110/119 and there is no reason that should not work.
Bob
How long will TIVO last?
Instalation help???
