Coming back to D* | SatelliteGuys.US
Coming back to D*
66mustang
151
5
Greeneville,TN
Ive been away from D* for a while and have decided to come back. I've read where some locals have moved. I was wondering what kind of dish i would get. I'm wanting 2 SD DVR's and a SD standard box for the kids room. My zip code is 37818. Thanks
No HD at all ?
Chances are you would still get the new Slimline stuff (5 or 3 LNB set up)
Otherwise you would just get the old simple probably single set up as you only need the 101 for basic programming.
As far as locals, they are still using the 72* slot for locals in some areas which would require a 2nd dish.
If your in the area that has moved to the new sats for thier locals, then you would get the 3-5 lnb sert up for sure, covering the 99, 101 and 103 sats
Jimbo
DirecTV Mail about NASCAR hotpass *Scratches head*
Direct TV HD service to all TV's?
