commercial lnbf | SatelliteGuys.US
commercial lnbf
coathanger
43
I picked up a california amplifed lnbf the other day at a flea market, my question is can i use this lnb on a primestar dish? looks like it will bolt right on. Specs are input:11.7-12.2 ghz Output :950-1450mhz,noise1.1 Gain55db typ. Appreciate any help at all.
Sure.... bolt it up and see how it works. Or if it works. If its a real Cal Amp commercial type it should be great. Does it have the stability figure stamped on it anywhere, or say "PLL" ?
Can Someone Recommend A Roof Mount
Primestar dish
